Simply a tech demo, rofl- don't even need to point out the obvious fallacy there. Yeah, was a very average game
You sure you weren't playing pacman?
What was so amazing about it?
I liked but the build up (apart from the annoying patrol boats i still have no idea why they even bothered to put them in, they were crap in far cry and they are still crap) but it went pear shaped from there on until the last couple of fights
Midway through the game thee is little or no guidance on what you are actually expected to do, prime example of this is
*SPOILER WARNING*
The level where you have to go to the graveyard, you spent ages driving around pointlessly getting from one side of the area to the other because there is no indicaton that there was a cliff that cut off what looked like the road to the objective
The levels may be large but they are very very linear, there is no free roaming you are filtered by invisible zone walls from one place to another and if you do reach a zone wall you suddenly stop as your character flops about like a hamster on crack. Theres nothing wrong with this, half life does it very well but crysis doesnt you can spend 15-20 mins scaling a hill for the perfect sniper spot only to find that you cant go any further because a leaf is blcking your way
The Ai is poor, there is no if's then's or but's about it, it is simply crappy and for me at least ruined the immersion
The story is average, and a bit weak at points, this may be subjective as i did play it off the back of COD4 and HL:Ep2. It reminds me of Prey somewhat, there are good bits but the crappy ones seem to drag the tone down.
The nano suite is a pretty good addition i really liked the customisation of the weapons but be honest, how many times did you actually feel the
need to use anything other than stealth and armour. Yes there are poorly disguised plugs to get you to occasionally use the extra toys but there is no real need other than that, you arent faced with enemies which require certain tactics to beat for the vast majority of the game. I felt while being good, the lack of utilisation of the suite to make the game more immersive and give you the sense of actually needing tactics cheapend the effect.
Yes you could go out of your way to use it, but then its the same as Assassins Creed you are doing things for the hell of it, not because you using tactics to take out kills
The weapons, these annoyed me the most, they were just poor i understand the need for realism but come on there isnt even any point aiming with the majority of them as they are likely to spray everywhere except where you are aiming so you are forced into using a handful of guns which are actually accurate enough to kill something with. Even on 1 shot they were horrible to snipe with.
