hiper media case
8 Jul 2007
Reading
Has anybody used the hiper media case and if so what are your thoughts on it.
Also is the power supply(200w) enough to run a basic C2D HTPC with 2400 pro GPU and 1 TB of HDD space?
Would there be any other alternative PSU's on the market preferably from OCUK;), that would fit in that case.
The problem with the case is finding a fan that will fit on top of a C2D processor as you only have 40mm of head room. Thats the main reason they still havent moved away from AMD
You could get away with the silverstone cpu coolers
Hiper also do intel low profile coolers i'm sure for their cases
