What PC games render fine at that res with less than 512mb of memory?
lemmings
Could you tell me which console you own and I could maybe write you alist of true 1920*1080 games that run on the 512mb ram you state is not possible.lemmings
Isn't CoD4 the pretty SD res you were after though?
If 512MB of RAM is not enough to render a game at 1920*1080 pixels, how do PCs with less RAM and bloated drivers/OS manage to do so?
1024x600 is still significantly higher than 640x480. One thing I wish to note; Call of Duty 4 runs and looks fantastic compared to a lot of other games out on the market. This is due in no small part to being 1024x600. If it was 1280x720p, the game would either run slower than the 60 frames it is already at (in fact, one wonders if the developers ever considered 1280x720p @ 30fps) or sacrifice a lot of the existing detail to maintain the frame-rate. It's the same for Halo 3 - if that was full 1280x720p, it would run like a dog.
I appreciate the correction, but my point still largely stands.
Erm... you know that neither the PS3 or 360 have 512MB of dedicated RAM right?
Else I get tired very quickly!!Yes, but that was not the point I was making. He stated that you needed 512MB VRAM, not I. I try to only correct one of his misleading statements per postElse I get tired very quickly!!
rp2000
you do need 512+ vram to render a game , like UT3 at 1920x1080, don't you?
the ps3 is faking 1080p by rendering the game at much lower resolution and then upscaling, is it not?
That's a very general statement that's just wrong, a 8800GTS 320MB can easily render a game (half life 2 for example) at 1080p, it could easily handle UT3 at low settings as well.
The game is actually rendered at something like 1066x600 and upscaled. So running at 1080p, there won't be any extra pixels, it's just interpolation.
Ridge Racer 7 on the PS3 is full 1080p. And look amazing, so it is possible, but rare. Maybe in a couple of years when programmers know how to get full power out of the PS3 can we see more 1080p titles
