Add me to the dirty disc error problem. How annoying![]()
such as Gears of War and Uncharted: Drake's Fortune
This is an RPG not an FPS![]()
By all means go in Mass Effect Defense Force Mode, at least the PS3 owners are having a break right now.![]()
lukly mine had saved just before , id be well peed if it hadnt as ive done the same bit over ad over lol.
To be honest it sounds like you're not playing the game right, the only people ive had real difficulty on so far with a soldier is getting wrex's armor(right after i left the citadel for the first time on hardcore). Its true the assault rifle does lose accuracy fast but crouching makes a hell of a difference and with overkill active you can spam to your hearts content as im still accurate with that even with a gun with an accuracy rating of 1. Im not sure about the rest of the team but it would also help if you set them to actively use techs/biotics in the options menu as that can help a lot and i find i can rarely be bothered to sort them out the whole timeI can see why it's not quite perfect 10/10 - the combat is pretty dire. You don't really 'feel' it. It's not fluid enough to duck and weave in and out of combat, with the cover system being horribly clunky. You lose accuracy in seconds even with full gun mastery (full assault rifle talents here), while your enemies can get you spot on everytime. Nearly every fight I just spam fire, and pray it's enough to get them before they wipe the three of us out. The slow frames per second during fights do not help much, neither does the ridiculous teammate AI - I have yet to be in a fight against more than 2 enemies where I'm not the sole survivor.
I can see why it's not quite perfect 10/10 - the - I have yet to be in a fight against more than 2 enemies where I'm not the sole survivor.
Dying immediately after a cutscene because a boss uses paralysis alongside troops shooting your body on floor without any control whatsoever of the situation, forcing you to actually drop the 10+ hours game save and start again from the beginning: oh deary me. This game stinks right now.
), I can see what he's saying.
), if you hadn't saved for 10 hours then, er, sucks to be you!!In defense to KNiVES (which I don't do often!), I can see what he's saying.
Without spoilers, the bit where you confront Matriach Benezia was just ridiculous, especially if your skills aren't high enough. I spent almost a full day on that to be confronted with the same thing: Start, go through door, endure cut-scene (and can't skip it!!), cover behind box, enemy use LIFT power up to lift boxes and destroy me. It was ridiculous.
In the end I just went and did some side missions for several hours to boost up skills, find more gear, sell it and buy better armour etc, which I understand is probably the 'better' way of doing it, but for someone who wants to get stuck into the main quest it would be tedious, boring, repetitive and just ruin the game.
I also saw an enemy I hadn't seen when I first went through the game - a Geth Prime. Think I found him on Virmire. He was a huge robotic geth who got the better of Kaiden a good few times.
