No I used a program which I thought re-encoded it, took several hours anyway. Maybe you can just rename the file extension?
You can't what you did is the only way, depending on PC spec and parameters it should not take that long. On a semi modern PC the content should re-encode in real time (ie 20 minute clip should take 20 mins or less to recode).
Anyway, I digress, I am stuck at work, who is going to chek if we have any new HD VideoMarketPlace content for me?
I don't care about this xvid stuff, but it sounds like a good compromise to me. Yes it doesn't work through media centre extenders, but more people will have access through WMP11 in my opinion. Looking forward to pressing all the new buttons and the faster dashboard!!!
rp2000
