I have a strange problem since the update - i log in okay, but the xbox busy just flashes round and round.
ah gotcha, you must have a faster connection then, mines been at it for a minute or so.
Nice sig btw
 Cheers mate.
 Cheers mate.
Just tried playing vids from a usb HDD, didn't recognise it. Is it possible at all?
Mine did that for about a minute, despite the 19mb connection lol. Thought it had killed the 360 for a moment!I have a strange problem since the update - i log in okay, but the xbox busy just flashes round and round.
so you can browse your computer fine through the video section ?
 Not sure whats wrong
 Not sure whats wrongHows it formatted? fat 32?
.Got everything working, had to use WMP11 rather then Vista's Media centre which is a bit of a shame but at least ever Divx & Xvid I through at it plays flawlessly, so much better then Transcode 360 ever did. It even streams the HD stuff better over the Wi-Fi then Media Centre somehow.
Really simple to set up
- Run WMP11
- Tools>Options
- Library Tab>Configure Sharing - Allow XBOX360 (make sure 360 is turned on), make sure everything is ticked in the setting box popup, then click OK
- Library Tab>Monitor Folders -'My Folders and those of other that I can access' in the 'Advanced Settings' just add all the folders you want to share and get rid of everything you dont. Click OK
And that should be it
That's right, any ongoing transaction is the same unless you actually cancel the subscription they can still take the money even if you have cancelled or changed cards.
thats ridiculous! i used my mates card as being 10pm the shops were shut. Ive tried removing it from the xbox. I made it forget the 3 digit security thing and his birthday in an effort for them to not be able to suck funds out of his account. But does this mean that they still will even tho they dont have all the information needed?
