- 27 Jul 2005
- The Orion Spur
I cant even get media sharing working (XP Prof with SP2 and WMP 11)
When I click share my media nothing comes up. NOt sure i have the network setup properly though - im such a N00b. I have read everything about it and it makes it so simple.
Probably doesnt help that I am on my work laptop, probably has some wierd security stuff going on. I cant see the bit where they say " Step Three - Click "Share My Media to" and then your Xbox 360’s icon." What Icon?
dude if your using XP download media connect 2 instead http://files.filefront.com/Windows+Media+Connect+20+English/;5479102;/fileinfo.html it's allot better than using MP11, once that is setup (make sure in media connect under devices your 360 is set to allow) then go into the 'video' option in the 'media' blade on your 360 and select 'X' for 'change video source' and you then should see your computer's name.
