I did some benchies on crysis for you guys
169.09:
05/12/2007 17:23:36 - XP
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 37.52
169.13:
05/12/2007 17:31:12 - XP
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 37.515
is the performance that bad for you? i have a q6600 @ stock, and 2 GT's, however until i get this extra long sli bridge i can only use 1 of them (both has S1's on them). and the framerate, with a modded cfg, is definately always playable.
I tested my fps on one map of crysis, then installed the new driver and I compared...
No difference whatsoever. Either I do something wrong, or you guys are just wishfull seeing.
edit: Greenboy has the facts.
I hope the crysis patch will give better fps and less bugs though.
i did. but as he said, probably wishful seeing. that and a new cfg
The CFG boost fps a lot considering that with CFG's you can run very high detail with the performance of high.
Any links to this?
No, its what I've seen on my PC, why not try the CFG for yourself? The current CFG I am using I dont think makes it look as good as very high, but its certainly quite abit better than high and also I get better performance than high.
