I'm planning a wet weekend with a straight test between a FuZion (with and without Nozzles), an Apogee GTX, Cuplex Di (last place guaranteed) and the EK Supreme, all in the same rig with just the CPU in the loop.
Niiiiiice
Has anyone got one that used to have a fuzion so we can have a direct comparison?
look forward to those results - have you bowed your fuzion?
The other option is to use a Lian Li G70 with a PA120.3 in the roof, but with a Laing D5 as that would allow me to vary the flow rate of water through the system, which might also very useful to know as the different blocks might respond better to different flow rates?
Yes, it's a sliver of what appears to be aluminium plate (although it could be stainless) and it appears to have been either laser or plasma cut - mine is particularly rough at the point where the cuts were initiated.
