Her we go then. I know you have been waiting for me to publish a result in here
CPU: QX9650
Revison C0
FPO# L739A640
Clockspeed: 4303 Mhz
Vcore (under load in windows) 1.432
Vid (core temp) Unknown
Motherboard: Asus Maximus Formula SE
Cooling: Water (single loop doing CPU, 2xGPU's and Chipset)
Thermal paste used : AS5
CPU Temp : 67c (average of the 4 cores - the Everest combined looks low)
I really hope thats everything, i so i dont fancy doing that test again for awhile... its a bit dull and very long![]()
Nice clock.
But I feel,and no disrespect to you.That penryn needs its own table.
Problem is, topic says quad core, and thats what the chip is.
maybe when a few more Penryn chips are benched, a new table can be made, but not yet, no point in having a table with just one entry!
I can separate the cpu's into 2 data bases, it aint a problem. I was considering this myself tbh.
You can't have a 45nm part in the same table as a 65nm part.
and when the normal non Qx versions come out - will they get to the same clock speed with the lower multi's - who knows.Nah it can be kept in this thread.
I created a 'reserved post' for this very purpose.
CPU - Q6600
Revison - G0
FPO# - L726A343
Clockspeed - 3915Mhz
Vcore - 1.56
Vid (core temp) - 1.2625
Thermal paste used - AS5
Motherboard - Asus Maximus Formula
Cooling - Custom Water
Next mission - 4Ghz
Update the database Webbo!![]()
