The Wales Lan Feb 22-25 2008
Bagsy having the same place as before. Was very convenient.
I think the room needs reorganised tbh. It was very messy and wasn't the best use of the room for the space.
Edit:
I think a layout similar to this would work best. My dimensions are totally out to be honest, but 2 people can fit to a table as several were last time. Also should cut down on the amount of cables trailing over the floor. You can have banter with more people in front of you and beside you.
I want to be by the radiator so I can make sure some nonce doesn't leave it on (Psymonkee excepted because he rawks and the ladies would hurt me if I was mean to him).
Kreeeee (and everyone else): FFS its hot in here, I can feel myself simmering in my own sweat.
Krono: Hmmm, they should probably turn the radiator off.
Kreeeee: Your not funny... Your not joking... How the hell can these guys sit here all this time sweltering to death and not know the ******* radiator is on. How do we turn this thing off.
:D
I agree with Windles idea, 2 to a desk is actually very easy, especially with everyone using TFT monitors.
Cables should be pre-laid and taped to the carpet to make it:
a) A lot tidier
b) A lot safer
It's possible to fit a lot more people in that room, even if it's simply putting tables alongside both side walls and along the window.
Edit:
The last time i had about 30mins total to arrange the whole room with no idea how it would play out or how many we could fit. Worry ye not this one will be better organised.
:D
Ah, that and punching you repeatedly in the arms... good times :)
Edit: And the girlies being scared of talking to good ol' psymonkee.
Got any big white walls in the gaming area? I might be convinced to take my projector for evening competitions tehe.
If you can get a space!
