most of the time on static shots I stick with the centre and do the focus recompose thing. though that might be a throwback to the days of one AF point for me.
thats exactly what i do. never served me ill.
That what I do 99% of the time. Im confused by the need for 51 points on the D300/D3. I can see me getting a D300, going ooooh... woooooowww at the 51 points, then a few shots later going back to the centre point.
And they'll release an app to overclock it, so you can get better AF speeds and higher AFmark 08 scores.![]()
Nikon D80 + 18-70 + 70-300 VR. It'll be roughly as much as the D80 + 18-200 combination, and you'll cover a wider focal range. Only downside is that it isn't all in one, but I'd rather have that combo since changing lenses isn't that time consuming.
Ok, well I've more or less settled on two camera's now. I've been to try out the Nikon D80, D40X & Canon EOS 400D.
While I liked the build of the D80, if I want other bits then it's out of my price range.
So this leaves the D40X and the 400D.
Having tried both, I'm happy with the feel of them, I can't decide between them though!
help!
Price range they're roughly the same.
Is lense availability good for the D40X? I had one shop tell me it would only fit certain lenses (where the D80 would fit all Nikon/Sigma/Tamron)
I looked at that one, plus the Pentax K10D which are more or less the same camera but decided against them, mainly due to features and functionality compared to the Canon/Nikon.
Based on the above and having tried them, I'm 90% going with the Canon at this stage.![]()
So, for ~1000 what could I get, to include the camera itself plus either/or telephoto + macro lenses?
Again, to compare these two cameras would not be a fair comparison.
