733.7 MB
what, thats quite a lot of updates
Sounds like more than the existing updates to me
733.7 MB
I already know the facts.
And yes pretty much rollup,but that fact still remains there must be more to it than that or there would be no need for beta testing.
The percentage of new to old stuff is irrelevant if it fixes just one more thing than before it worthwhile.
You should also check the context to which im replying to then you would have understood that i was not saying that it was not pretty much a rollup, but a rollup but with a few extras, but the few extras are different enough to need beta testing.
There is always a need to test it, whatever is included. For lots of reasons which should be obvious.
Good point.![]()
hehe, you're just asking for trouble.![]()
When SP1 final is out won't you have to uninstall rc1 first?
Some people are gonna be peeshed!
Well I have installed the 32bit release onto a laptop that was sufering from a problem detecting and installing USB devices and it has fixed that issue.
Did you have all the Updates before had.
Why install RC on live systems when Gold will be available soon anyway?
Noticed one thing that in control panel, classic view you now cannot change the icon size.
right click > view not working for you then? works fine here.![]()
