Tri-SLI benchmarked
Caporegime
6 Dec 2005
Birmingham
The German print and online magazine PC Games Hardware had the opportunity to bench Nvidia's tripple-SLI. The benchmarks have been done using Crysis and some other games. Unfortunately a unreleased Crysis build with number 5837 was used which seems to be optimized for triple-SLI. This new patch will be publicy available in a couple days.
So far only te 8800 GTX and 8800 Ultra are capable of running triple-SLI. What else is needed to run triple-SLI?
- 3 Geforce 8800 GTX or Ultra cards
- a 3-way-SLI_Connectorboard (or as a alternative: 2 very short and 1 very long SLI-bridge)
- a mainboard with 3 PCI-E-x16-slots (680i or the upcoming 7x0i)
- the right Forceware driver (in this case 169.18 was used)
- a PSU that is strong enough to provide enough juice =)
Nvidia recommends using at least a 1,100W PSU. The Thermaltake Topower that was used in the test was really stressed. The kill-a-watt-device showed a total power consumption of 819W.
The benchmarks were done with a system that Nvidia provided. It's specs are:
CPU: Core 2 Quad Q6850 @ 3000 MHz (333x9)
Board: Asus P5N32-E SLI with Nforce 680i-Chipsatz
RAM: 2x1,024 MiByte Corsair Dominator
OS: Vista 32 Bit (Enterprise Edition)
As tests were used:
Tests:
• Crysis Build 3857, PCGH-Ice-Benchmark
• Unreal Tournament 3, PCGH-vCTF-Suspense-Benchmark
• Fear v1.08, int. performance-test
• Company of Heroes, int. performance-test
VGA: 3x XFX Geforce 8800 Ultra (612/1,512/1,080 MHz)
Driver: Forceware 169.18
Article
Pics
it isn't that great.. between sli and 3-way sli it only adds 10.8fps which isn't much...
It is almost a 40% boost... over a 2 card SLi setup in Crysis.
10fps doesn't sound much, but when the other setup is only getting 27fps, percentage wise its a good chunk.
Still wouldn't have a triple-sli setup myself.
2 cards is the best option for money vs performance. Unless Nvidia tweaked the 3 WAY SLI to add at least 30 FPS to crysis.
3 8800 Ultras = £900
1 Tri Sli Mobo = £200
1 1200W PSU = £150
The look on your face when you realise you still can't get and more than 40fps stable in Crysis... priceless.
Quad sli was also pretty crap. Tri sli seems to have improved somewhat though but not as much as id expect.
On another subject wtf is 1xfsaa 1xaf?
:eek:
:eek:
Quad SLI was very good in OpenGL.
Just not DX. :)
Either way, dropping that much cash for borderline playability is somewhat amusing.
