GTS 512 V GTX in 06 ( the myths revealed)
Status
Not open for further replies.
Caporegime
24 Dec 2005
Autonomy
Please bench your GTX against a GTS 512
Thanks
No ifs not buts.
We all play from the same benchmark.
Default res
Performance
etc..
Don't want to chat about AA and AF I want a professional Bench,
If you don't know what this is then don't post.
It's as simple as that.
Main Test Results CPU @ 4035 MHZ
3DMark Score 17443 3DMarks
SM 2.0 Score 7267 Marks
SM 3.0 Score 6935 Marks
CPU Score 6347 Marks
What clocks you at, we'd need to know that for a like for like comparison?
Nice score by the way!
EDIT: And how are you going to take the different CPU's out of the equation?
Max clocks for your hardware
800/1945/2200
how can u put a max clock on a see what is best thread?, it should be if you'r card clocks this high use use it as that shows what you'r card can do as the how can u put a max clock, it should be if your'e card clocks this high use that as its a card v card so that should include overclockability should it not? its as important as stock v stock
All runs at Clocks 820/2200
Q6600 @ 3Ghz
DX9
Crisis GPU run
1920 x 1200 everything on high apart from post processing which is medium.
1680 x 1080 everything on high apart from post processing which is medium.
Default res
Because I know its slower at a high res than most serious gamers use these days
...theres a surprise, wonder why?
Come on easyrider please do show us these myths you refer to rather than spout drivel once again about how the hardware you own is better than anyone elses.
Not doubting the GTS is a great card for 3d06 as your score proves or indeed that it is a great all round card. This however is common knowledge but is misleading others into believing the GTS is a better card than the GTX which we both know just aint true. If you are going to reveal myths then I feel that the above comment had to be made.;)
how can u put a max clock on a see what is best thread?, it should be if you'r card clocks this high use use it as that shows what *** card can do as the how can u put a max clock, it should be if your'e card clocks this high use that as its a card v card so that should include overclockability should it not? its as important as stock v stock
Its dead easy.
Have a Quad?
Have a GTX?
Post your 06 mark
Would you do the crisis test mate?
I'm re running with all on high
Just post your GTX results with your Quad @ 4ghz
Its simple
Not got it installed m8.
Just post your GTX results with yoour Quad @ 4ghz
Its simple
For what reason. Its scores less at the res 3d06 runs default at. I however dont game at 1280x1024 and havn't done for a couple of years at least. I buy a graphics card to play games. I buy a powerful graphics card to play games at the best quality possible.
Please don't get me wrong. I am not saying the GTS is crap but anyone worth there salt should know that comparing one card next to another in an outdated benchmark is pretty useless tbh. We need a DX10 benchy with AA and 1600x1200 minimum res.
Get a grip for gods sake lol the card is £210 delivered not like your on some elite level.
If you want a high 3d mark score get sli gtx ultra and clock those under water.
if anyone has full 3dmarks06 can they do a run with a gt @ 1920x1200 as 1280x1024 has no intrest to me?
I'd love someone to come along with 2 gtx ultra under water and burst your bubble but i doubt they will.
Get a grip for gods sake the card is £210 delivered not like your on some elite level.
Read my OP:)
Lol at you two and your £150 gt's and £200 gts although i am jealous
Awfully proud aren't we i still didn't see the crysis 1680-1050 bench of your gts asgard ? is it 70fps average ?
what's professional about clicking 3dmark06.exe btw ?
Its simple
Why not just compare your results on the orb? GTS512 doesnt justify the cost over a gt atm for me, my 2 3870's some how do at almost 20k ( for abour £40 more than a single gts) its swings and round abouts
I agree with the OP. It would be interesting to see a fair comparison. Perhaps to make it easier for someone the CPU quad should be at stock also? or perhaps one at stock and one at 4ghz?
Just plugged my new BFG 8800 GTS a few hrs ago, loving it so far.
Status
