8800Gt 730/1763/950
1680-1050 everything high post processing on medium this is high performance set in nvidia controls btw
ARE you sure you guys haven't changed anything are you using dx10 visuals config for xp ?
there is high performance
performance
quality
high quality we need to establish which settings everyone is on and know if you are using the dx10 visuals config for xp.
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 42.44s, Average FPS: 47.12
Min FPS: 32.81 at frame 142, Max FPS: 60.42 at frame 1010
Average Tri/Sec: -44503516, Tri/Frame: -944449
Recorded/Played Tris ratio: -0.97
!TimeDemo Run 1 Finished.
Play Time: 38.40s, Average FPS: 52.09
Min FPS: 32.81 at frame 142, Max FPS: 68.39 at frame 104
Average Tri/Sec: -48527576, Tri/Frame: -931620
Recorded/Played Tris ratio: -0.98
!TimeDemo Run 2 Finished.
Play Time: 38.35s, Average FPS: 52.15
Average Tri/Sec: -48573448, Tri/Frame: -931454
!TimeDemo Run 3 Finished.
Play Time: 38.37s, Average FPS: 52.13
Average Tri/Sec: -48548528, Tri/Frame: -931338
TimeDemo Play Ended, (4 Runs Performed)
Press any key to continue . . .
performance
quality
