Azureus problem.
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi, I am trying to set the torrent app up, but the problem is when I type the port in it always comes up with this:
The problem is I've tried forwarding the ports in the router and no firewall is stopping the ports so what could be wrong?
I've followed that and not one single port I try works.
Could this be why? Also I got failed at the top aswell.
GRC Port Authority Report created on UTC: 2007-12-14 at 21:12:18
Results from scan of ports: 0, 21-23, 25, 79, 80, 110, 113,
119, 135, 139, 143, 389, 443, 445,
1002, 1024-1030, 1720, 5000
0 Ports Open
0 Ports Closed
26 Ports Stealth
26 Ports Tested
ALL PORTS tested were found to be: STEALTH.
TruStealth: FAILED - ALL tested ports were STEALTH,
- NO unsolicited packets were received,
- A PING REPLY (ICMP Echo) WAS RECEIVED.
you need to use a random high port as mentioned above. and why the hell are you using grc.com - that's of no help whatsoever. the test button in azureus works just fine.... :p
I tried random ports, every single port was showing message that was in screenie in OP. SOmetimes there was extra saying that the Port could be blocked.
i just noticed on your screenshot, your router supports upnp. have a look at that and enable it. there should also be settings in azureus to let it work with unpnp - give that ago.
Has nothing on UPNP.
well i can see it in your router settings as i mentioned above, and i know azureus has it. try harder. :p
edit: you shouldn't actually have to do anything in azureus - just make sure it's enabled on your router and azureus should automatically open and configure the ports you need.
