3870 x 2 is simply crossfire on a stick. (ie two seperate gpu dies on one pcb)
Seems ATI have more interesting cards around at the moment. I would really like to test even the HD3850 and HD3870.If these are around £240 I might get one.
[edit] anyway back on topic I suppose there is a chance that one of the new HD 3890's may actually use less power than the older HD2900XT due to the newer low powered cores!![]()
Feel a bit better for shelling out an extra £25.00 on a Corsair HX620W instead of the cheaper HX520W.AMD reckon Crossfire 3870s need a 550w psu
For the same price as a current 8800GTS-512MB you could have CROSSFIRE HD3850's which doesn't seem such a bad choice for those who like to play!(and most INTEL users have a nice CROSSFIRE ready mobo).
I still haven't decided which GPU I will have installed for xmas, I'm intending to play through the Half-Life series at 1920x1200 so looks like I could get away with even a £100 ish HD 3850.
RIP
It would appear the 3890 is SHORTER than an 8800 Ultra
I hope not, those cores are meant to run a lot cooler than the previous ones used on the HD2900XT.I rekon the fans on that thing will have more suction than a dyson cyclone thing.
Also I'm sure AMD/ATI got a lot of negative feedback about the HD2900XT so hopefully they will learn from that mistake and get nice quiet coolers designed.
The new 8800GTS 512MB Cooler is ace, hope the new Radeon has something similar.
It looks almost the same as a 2900XT's cooler just abit weird shape
Now looking at that picture those do indeed look just like the coolers featured on the HD2900XT, real big mamas and noisy as hell too! I mean Tom|Nbk owned a HD2900XT for a few months and look what the fan noise did to him!
I was thinking that since these new cores use a lot less juice and generate less heat that the cooling would be quieter, silly me of course there will be two cores so that brings the TDP backup to HD2900XT levels?
AMD are gonna do it again, they are gonna release these new HD3890's with monster loud coolers!![]()
