Anyone been to The Fat Duck?
Man of Honour
11 Mar 2004
For those who don't know its Heston Blumenthal restaurant. He's an amazing and unconventional chief. Yes the inspiration is because he's on channel 2 now.
So has anyone been?
If so what was it like and how much can you expect to pay?
He cooks in a very scientific way and yes it does take ages to create his dishes. But after all he is looking for perfection.
Hoping to go sometime in the new year. I believe the tasting menu of ~12 small dishes is about £125, whilst you can go for a three course a la carte for something like £90, depending on the wine options you choose.
That's not horrendous for a special occasion. Or a special treat. You'll have to report back on what it's like.
In what way?
In that the final one he came up with to get the best taste and what not seemed a lot of arseing about to just make a chilli
People havent got time to get as anal as he does while hes cooking, hes good and i like him i just couldnt be arsed with attempting to follow his recipe
In what way?
read this page, shows how much effort he goes to.
http://www.timesonline.co.uk/tol/life_and_style/food_and_drink/heston_blumenthal/article624364.ece
|cooking steak for 18 hours
1 Using an oven thermometer, preheat the oven to 50C/120F/Gas Mark .
2 Place the fore rib in a roasting tin. Brown the outside as quickly as possible using a blowtorch. (If it’s not hot enough, the flame will start to cook the flesh. If yours isn’t up to the job, use a very hot pan instead.) Once the meat is browned, place it in the oven. Use a digital probe to establish when the internal temperature of the meat has reached 50C/ 120F (this takes 4–8 hours, depending on the animal; don’t let it go any higher — it will ruin the recipe), then let it cook at this temperature for a minimum of 18 hours. Remove from the oven, cover and leave to rest at room temperature for 2 hours — 4 would be better — it’s important that the meat cools down before it is subjected to the fierce heat of the pan.
3 To prepare the steaks, hold the fore rib upright with the rib bones side on. Run a sharp knife between the meat and the bones, and free what should be an L-shaped piece of meat. Trim off any overly charcoaled exterior. Slice the meat in half vertically to give two steaks, each about 5cm thick.
W of the steak, it kick-starts a complicated process known as the Maillard reaction, which adds depth and complexity to the flavours of meat. To get those flavours without drying out the steak, you need to brown the surface quickly and then take the heat right down. At the lower temperature, muscle proteins contract and squeeze out water more slowly, which is crucial to
keeping the meat moist. But the steak also needs to be tenderised, which, at this temperature, is done by enzymes that weaken or break down collagen and other proteins. Heating the meat slowly means these enzymes can perform their magic for several hours, effectively ageing the meat during cooking. The result is the tenderest, tastiest steak imaginable.
4 Place a large cast-iron pan over a high heat for at least 10 minutes. Meanwhile, take the blue-cheese-infused butter out of the fridge and remove the cheese. Crush the peppercorns using a pestle and mortar, add a little of the plain sea salt and smoked sea salt, and put this mixture on a plate. Dip both sides of each steak in the seasoning.
5 Add a film of the groundnut oil to the pan and, when it’s smoking, add the steaks. (The surface of each steak needs to be in contact with the pan, otherwise they won’t cook properly. If they overlap, fry one at a time.) Fry for 4 minutes, flipping every 30 seconds. They should develop a nice 1mm brown crust, while the interior should be uniformly pink.
6 Let the steaks rest. Allow the frying pan to cool slightly, then add the flavoured butter and stir to melt it and collect any bits of meat that remain. Pour into a jug.
7 Cut the steaks into diagonal slices. Add a few grindings of black pepper, and a sprinkling of sea salt and smoked sea salt, then drizzle the butter on top. Serve with a dollop of mushroom ketchup and tomato ketchup.
He seems like a douche bag to me, like he's trying to re-invent the wheel, and it's not even scientific what he does. There is no such thing as a flavour molecule!
Perhaps not but a lot of it is. Things like the way flavours are tasted and transferred in the mouth. like fat coating the tounge.
Things liek cooking meat slowly but for ages to actually break down the tough parts. It is very scientific.
I'm not disagreeing with you, i'm sure his food and recipes are fantastic , but the way he comes across when he presents sounded like he has little scientific knowledge.
Its kinda common knowledge really.
Best beef iv ever tasted was some i whipped up on friday, oven on @ gas mark 4-5 at 11 o'clock, bit of butter+stock over the top of it, chop aload of onions, bit of foil to shield it.
Go to pub.
Text flatmate @ 3 telling him to whack up heat a bit to about 5-6, come back @ half 5, whip up some more gravy, chop some veg, pour in. Mix around, pour half can of cider in, stick fork in joint, joint breaks in half at this point(and i wet my pants with excitement)back into oven a little higher for a bit to fire up the gravy etc.
Make some mash potatoes, pigs in blankets, yorkshire puddings(all whilst hammered)
Sit down and eat, best beef iv ever tasted tbh.
Longer you cook it for the better it tastes tbh, aslong as you're eating its stock in some way. This guy is basically following old housewive ideas but overcomplicating it and applying science precisely(not really required.).
Bit anal how precise he is, but guaranteed the stuff will taste good, since it seems to be based on methods developed over ages past.
why? and what's happened toy your MOH avatar?
That usually happens when people try explaining things in laymen terms.
I wouldn't go on principle because I get the impression Blumenthal is like a poncy artist doing things just to rock the boat and I hate pretension of any kind - he has it in abundance.
As for my MOH avatar, I wanted to try out the new ones but I couldn't change it back after. :( *
(* Perhaps a friendly Mod will change it back for me, pretty please, I promise I will be good. :) )
well it is meant to be perfection
Not really the same. He cooks stuff for 18hours + with no juices escaping. So nothing to make the gravy with. Using liquid nitrogen to make the best ever ice cream.
It's not stuff you would cook often. But I think I'm going to try some of his in jan. And see really how good it is.
email gilly, he'll sort it for you.
