Can anyone please tell me 100%, which imaging software works with the P35 chipset. I have been using Acronis for the last 2 years, but it dos'nt seem to work with the P35. I can't find any compatibility info on Ghost, for the P35 either.
I am using ATI Workstation 9 with the P35 chip and it works fine, using ATI Home 10 with X38 chip...found the ATI W 9 would not work with the X38 chip.
If you have a Seagate or Maxtor HDD in your system, you could use DiskWizard or MaxBlast...which is basically ATI Home 10 minus a couple of insignificant features...![]()
More than likely down to the SATA controller and not having drivers to support it.
Acronis works on mine (Gigabyte P35 DQ6) as does Ghost.
M.
