Model: M240UW01 v.0
Bought 9 days ago. Fine so far.
I am not trying undermine the people that have genuine problems with the monitor, but I get the feeling some people look for problems straight out of the box, Instead of enjoying the monitor for what it is.
For example, In normal use, have you noticed any dead pixels? If not, why go looking for them?
If the colours and backlight are fine in normal use, why create artificial environments that will show up the slightest fault?
I have been guilty of this in the past. When I was researching a particular item, I would focus on the negatives, however small, and forget any of the positives.
Try the screen for a few hours first, then make a decision. Too many people run tests as soon as the monitor is hooked up, looking for faults. If you look hard enough, you can find faullt with everything.
Not trying to undermine, but snipe away ?
Jeez.
I don't think you have read what people are saying. For me , the screen out of the box was fine, however, the backlight issue got worse over the next 10 hours of use.
I always let a monitor bed in for an hour or two before doing anything, so nothing straight from the box happens.
I hardly Think checking for dead pixles is a negative thing, they need to be identified early to give you the most time possible to work on them and remove if possible. Nor do I see it a bad thing to check the panel for colour and backlight uniformity. I can not follow your logic here.
As I said in my original posts, I had a dead pixel (just the one) which I was happy do live with, but not the second fault.
If all you do with your monitor is display interesting wall papers and occasionally look at the internet, then any screen with any fault will do, however, seeing as most people actually use their screens to the full and for many years, it seems only sensible to check and ensure you havent been sold a dud quickly, as DSR only give you 7 days to return if not fully satisfied.
AS for most of the faults reported thus far, you didn't have to look "too hard" to observe them..infact I could see mine in game.
Perhaps you can pass comment having a perfectly acceptable screen, but please do not try to undermine others who are not as fortunate as yourself in that respect.
