I think AMD's done quite well there, making a dual GPU card that isn't like 1.3x the height of a standard graphics card (X1950 Pro Dual, 7800 GT dual) without using dual PCBs (7950 GTX).
Easy 4 way crossfireSo who's gonna buy 2? hehe
Matthew
Will these function as 2 cores on 1 card like a dual core CPU or will it function like crossfire?
Crossfire.
Sure have. However what it lacks in girth it makes up for in length, and then some.
Damn that's long
id imagine theyd function like 1 card as thats what it is, like to old 3dfx voodoo 5500 cards, with performance matching or beating 2 3870s in crossfire but without the hassle of it
I can remember not so long back sites were claiming these would break 20k in 3dmarks 06 if thats the case then they will perform better than crossfire as to get that kind of score you need a pretty highly overclocked cpu and clocked crossfire gpu's. Just have to wait and see as it was most likely a lot of speculation.
