Half Life 2 - stuck - PLEASE HELP!
5 Jun 2005
Southampton
as far as i can see i'm almost at the end, however i seem to be stuck.....
(see pic)
i can't seem to go any further than this fence as i can't jump anymore? is this normal? i looked at a walk through guide and for some reason this is not covered,,, how do i get to the area in front?
At no point should you be unable to jump :eek:
Check your key settings, start a new game and see if can jump.
I haven't played it in a while, but there is a point in the citadel which requires jumping over a fence, but I'm not sure that's it. Are you somewhere you're not supposed to be.
If all else fails of course
sv_cheats 1
noclip
and fly through;)
dont you just jump down onto that ramp straight infront of you?
not 100% sure which part you are on in that picture, though i should know as ive played the game through enough times. :)
its a glitch in the game.....i was stuck in the same place...in the end i googled it and i found the solution...but i just cant remember what i did...it was in a walk through i found...search and you should find it
Yeah lots of people get stuck there, it is some kinda bug to do with not being able to jump. Noclip your way through it or you'll have to redo the level.
wow strange! i loaded an older save game and was able to jump! thought it was strange! really had me baffled! now finished the game......er so what happend at the end!!!???????
