Right, so my 2gb iPod has finally packed in and I'm in need of a replacement. I'll happily shell out the money for a 16gb Touch if I feel it's worth it pending a few questions answered.
I'll be using it at work, in the gym, outside running or cycling so it'll take some knocks and scratches, get dropped, be operated with oil/grease/muck on my hands. Also might not be able to charge it for a few days at a time.
I listen to audio books and music (might do video if it's practical) so 8gb is probably a minimum, old 2gb was far too little.
Are the 80gb/160gb Classics solid state storage or are they likely to not respond well to vibration/trauma etc? Though 80gb is possibly overkill anyway.
Pocket space isn't too much of an issue, my pockets are generally full of crap anyway so the differences in size won't matter too much.
So which iPod would you recommend?
Thanks in advance.
Thanks in advance.
). She is getting used to itunes and loves the classic, interface is a tad slow compared to the old Zen though. I got her a opaque rubber case as well to keep it scratch free. Lovely peice of kit and I managed to get £20 discount from an online retailor as well.
