**Updated 1st post**
On monday i got hold of the Swiftech H20 220 compact kit. Now ive been toying with the idea of going towards watercooling for awhile now, but going custom seemed complicated and i was too worried of getting it all wrong, so i put it aside. But then i spotted this water cooling kit and give it some thought.
But then i noticed a place which cannot be mentioned had them on there site. So i gave them a quick call and they just had them delivered.
So i hopped on the bus and got one and got a bottle of Fazer aqua destilled water too.
Got home and like a little kid i ran upstairs to my room, shut the door and had a look at it all.
1st impressions where great, you gotta love the "new thing smell". Box had a neat design and after opening it up it was neatly and tightly packaged.
I had a good read though the instructions which was very through indeed with plently of pictures to teach a noob like me how too set it all up.
After a good hour ( i think ) of setting it all up and plumbing it together i hot-wired my psu with a paperclip (Even tells you how to do this in the instructions) and started primeing the pump and filling it with water. Which the instructions said to do for a hour ( Or more ) so i stuck a film on and kept a eye on it.
Once that was done (Needed to rock my pc case abit to get a small amount of air out) I attached the cpu block to the mobo with the back plate supplied.
Now since i installed the kit ive been running my pc at 3.6ghz @ 1.475v and all has been well. Its stable in prime95 and ive now just ran afew tests at different rad fan settings to show you my temps.
I ran Prime95 for the 1st test with the fans at 50% on my fan controller and 100% on my fan controller. And also recorded the idle temps for each 50% fan and 100% fan.
1st are the idle temps:
Rad fans where at 50%
Core 1: 28c
Core 2: 23c
Core 3: 23c
Core 4: 28c
Rad fans now at 100%
Core 1: 28c
Core 2: 22c
Core 3: 22c
Core 4: 28c
So as you can see, Not much differance at all with the fans set too 100%
So now i set Prime95 running and recorded the result after the 1st test had finished.
1st with fans now at 50%
Core 1: 49c
Core 2: 44c
Core 3: 44c
Core 4: 49c
Now i set the fans too 100% and restarted Prime 95 again once the temps had gone back to idle.
Core 1: 49c
Core 2: 43c
Core 3: 43c
Core 4: 49c
Again only a very small difference with the temps again with the fans at 100% And i must say, the stock fans at 100% are very very loud.
Over all im very happy with this product. Its 10c cooler atleast at full load than my noctua ( I would include more pics of my noctua temps, but ive formatted since then )
Like already said the only problem i have with it is the fan noise at 100%.
Otherwise its a great product and swiftech have done a great job to get us watercooling virgins to take the plunge.
Also this is my 1st ever review ive ever done so be nice
Prime 95 2 hour test results:
Core 1: 46c
Core 2: 39c
Core 3: 39c
Core 4: 46c
Temp log for the 2 hour test:
http://www.sendspace.com/file/fis0ez
Core 1: 28c
Core 2: 23c
Core 3: 23c
Core 4: 28c
Core 1: 28c
Core 2: 22c
Core 3: 22c
Core 4: 28c
Core 1: 49c
Core 2: 44c
Core 3: 44c
Core 4: 49c
Core 1: 49c
Core 2: 43c
Core 3: 43c
Core 4: 49c
Core 1: 46c
Core 2: 39c
Core 3: 39c
Core 4: 46c
