- 9 May 2007
hi, i going to buy the cool master cm690 and i was thinking of doing a bit of air brushing but i never done anything like it. so can some one comfirm is this the technique:
1) remove the paint on the case untill i see the metal (BTW how do i do this? and do i really need to do this cuase i was gona paint ti black background anywayz...)
2) put metail primer (that to fill gaps and dents but if i dont have no dents do i really need to apply this?)
3) sand it down with 2000grit sandpaper for extra smoothe
4) apply colour and allow to dry
5) for me.... air brush a picuture on
6) let it dry
7) spray cleear stuff on it(is this laqure? whats does it do? stop paint from comming off?)
done??
6) let it dry
done??
hope he comes on and tell me a bit
