*** OcUK Crysis DX9 TopList ***
40.72 fps
Sinny
e6420 @ 3.44Ghz
8800GT 512MB @ 680/900
XP 32bit
19.275
Dazman
Intel E4400 @ 3.0(ish) DDR400
Gecube TEC 256Mb x1950XT AGP @ 709/909
XP 32Bit
The shaders at high kills this card, at medium I get 29Fps average a 33% increase. I don't notice any image quality differences either but I know there must be something!
That bench util doesn't work for me, it just crashes on load, so i've done the normal GPU bench from the Crysis folder with the settings asked for in the first post.
Q6600 @ 3Ghz (333 x 9)
4GB Geil ULL @ 833Mhz 4-4-4-12
8800GTX @ 621/2000
WinXP32 - 169.21's (Quality Settings - No AA)
Updated for overclocked GC, gurusan can you do the honours on the table please mate?
46.22 fps
randal24
e6600 @ 3195mhz
8800 GTS 512MB OC'd @ 725/1812/2000
Vista 64
er chronic, that looks rather low for your rig, everything ok?
No idea tbh, i get good results on most other games except crysis :s (over the 10k mark on 3dmark for example)
It could be because i havent defragged in a while, i will give that a go and try again when i get some time (been avoiding it as it takes literally hours, 1tb array etc)
One thing i did notice though, when i put my card on performance mode opposed to my custom settings i get a lower fps
same for some reason - worked fine earlier - if you copy and paste the image location tho it shows the image...
Interestingly I've been playing with SLI and Crysis and found a way (atleast with the GX2) to MASSIVELY boost performance... while its still not as high as when I'm playing, its decent enough to post a benchmark I think... still not sure if my performance was slow tho due to my own tinkering or if nVidia set it up wrong in newer drivers heh.
Also, is there any way to insert HTML code into a post?
There has to be some easier way of posting something from Excel?
