- 3 Nov 2004
- UK
Noctua would be quite a bit worse. What you're looking for is high pressure and CFM with reasonable noise. The PA series is optimised for flow rates upto 110CFm iirc. So fans like the ones below would do well, assuming you can find them. I'm having a terrible time finding high CFM fans that don't sound like Harrier engines. If you get really stuck SilverStone FM121 might do, but the quality's not all that good imo.The pump is a 10W Laing DDC 1T Pro, I was thinking of upgrading the fans but would need something with a controller on each. WOuld Noctua fan's hand le it better or are the current ones better than the Noctua ones?
Sanyo Denki 109R1212H1011 or 109R1212H101
or
Panaflo FBA12G12U1A or FBA12G12H
The PA120.3 would be a good move for that combined heat load.I was going to put a GTS 512mb on the loop but might upgrade to a 120.3 if better fans & 120.2 wouldn't handle it
..love to know which of the bios settings seems to have eliminated the vdroop.
