- 7 Mar 2005
- LU7
Away you go then.
Oh dear god!EAC is the best bar none - but you have to configure it properly and learn it.
this is the best guide there is for EAC.
http://www2.firehose.us:81/~jiggafellz/eac/index.html
I hope there isn't a load more detail I could be getting. I wouldn't want to feel that I have to re-rip nearly 6000 tracks.
So I could, conceivably, make FLAC copies of my music for archival/transcoding purposes and use the MP3 copy for everyday use?Indeed. You could listen to the FLAC copies whilst at your machine but when you need them to be on your iPod or similar you could transcode to apple Apple lossless or AAC or mp3.Ah I gets ye now.So I could, conceivably, make FLAC copies of my music for archival/transcoding purposes and use the MP3 copy for everyday use?
if you're worried about more detail, you should be ripping in lossless really!
-V 0 --vbr-new is the only quality setting you should be worrying about. if your using that, its all good![]()
Cheers BillytheImpaler and james.miller.![]()
i never said v0 lame was lossless. i was referring to ripping in flac rather than lame![]()
