What do you mean by revision?Is there any particular revision of the mobo i should go for?
Do you mean version or?
Sorry to go off topic, but I thought you had the Asus P5K-E?? I thought you always went with the cheapest value for money lol. (thats a good thing by the way, wasn't taking the ****.)There both top mobos, each have their own minor strengths and weaknesses, would be like comparing a Big Mac to a Double-Whooper
I went with the ASUS board although I was very tempted by the ABIT.
I do?I thought you had the Asus P5K-E??
I do?I thought you always went with the cheapest value for money
yes, my thoughts are I'm not sure what your question is?Any thoughts to previous question ?
Does the 2.00g revision fix the sata problems??The later revision is 2.00g which i would suspect is all you can buy now. They dissapeared for a while and when they came back in stock they were the 2.00g.
You will need to have a good read through but:-What SATA problems?
Click Here
Click Here
Click Here
Certain Sata II drives, not sure about Raptors but they seem to be incompatable - Seagate 7200.10's & 11's seem to work fine.
P5K? P5K-E, P5K-Deluxe? P5K-Premium? which version?I'm about to get a P5k
Like I said, it seems that Seagate 7200.10's & 11's dont appear to have this problem but it has to be a bug with the actual motherboard because other drives work flawlessly with any other motherboard.It seems some people have had issue while using 'RAID' and 'ACHI'. Does it say there is a problem with regular SATA disks at this time?
That looks a good board, everyone has had good reviews of it, will be even better if they fix the V-droop that affects the latest two bios updates for compatability with Penryn CPU's even with the voltage dampener on.Asus P5K-E WiFi
Different board, seems there are some teething issues with the *Premium* version but as far as I know this doesn't effect the other boards?Asus P5K-E WiFi
