ye jus installed, played through the first 5 minutes of the first level (i always do it to measure performance after tweaking so its a fair test) and there was no realy difference compared to no patch installed.
here is my spec:
q6600 @ stock
2 x 8800 GT @ stock set to alternate frame rendering 2
2gb pc6400 @ stock
169.09
installed it, and tried the gpu bench, massive gain of 1fps same settings i have listed in gurusans benchmark thread, not even worth uploading a screenie.
yeah just tried with the newer 169.28 drivers. all same settings, same part of the level, no difference. and yes im certain ive enabled sli in the control panel etc etc.
ive been using that for a long time m8. makes no difference really. its always at 30 fps, which is good, i was just hoping this patch *** mean it would never go lower than that.
baring in mind i am all at stock, im sure some overclocking could push it to the levels that this patch promised
