Vista is fantastic
This a common occurance for new Vista users. There is just so much misinformation out there that people just assume it is a load of crap and that is "Windows ME Mk 2"!
I heard this again today. Was onsite & client said 'so what do you think of Vista?' before I had a chance to say anything, he carried on '..because I heard it is as bad as ME!'. :rolleyes:
I love Vista 64, very stable all ym peripherals work fine, all drivers work fine all software works fine (in terms of hardware/software I use, not all software peripherals)
Oh yes you will if you have a Raptor 150 or using laptop. It will eat away your battery and reduce your HDD life expectancy down to 3 days.
3 days? HDDs are designed to be used, it's not doing anything adverse to your HDD's lifespan whatsoever.
I've found Superfetch to be very efficient. I get out of bed, turn my PC on and go downstairs. Come up again a couple of minutes later, and the apps I usually run (MSN, Firefox and Winamp) appear instantly. Same couldn't be said for XP.
Utter rubbish. Hard drives in servers on constantly reading and writing for years with no failures. I don't like Vista though
I used to hate Vista. The 32bit Version though, everything I tried with it went belly up at some point Pre Release and after. So one day i took the plunge bought Vista 64 with a huge amount of apprehension and Hey Presto the perfect OS imo.
It was actually something NathanE said a while back that got me thinking, in some regards we are Pioneers of this OS, backwards step thinking that XP was the be all and end all..... Wise words :D I still dual boot though purely for a few games that are 16bit written, old Amiga Games mostly that I still enjoy to this day. Otherwise Vista 64 all the way, actually find the Driver support better for 64 than 32 is way better.
The only thing I dont like about vista is the speed of transferring files, however I now use teracopy which has solved the problem..
Wow. Ive never seen a thread which started with I love vista. . . .
For the record, i am a happy and satisfied user of Vista x64 and find the gaming more stable than XP. People are still regurgitating the info from the first few weeks not realising that its now a decent OS which suffers few problems.
Well, that was a figure of speech, I didn't literally mean that your hard drive will last 3 days!
When I first installed Vista, I noticed my HDD was thrashing for hours on end, I thought Vista was re-configuring itself or something like that so I left it for work, but when I came back it was still going strong. I did some googling and found out so many people have the exact same problem. Raptor 150 is so loud compare to my other WDs (500GB) and the noise of constant disk thrashing was just unbearable.
I don't really notice any difference in terms of performance at all. The programmes I use often load almost instantly without Prefetch anyway so can't be bothered with it.
To disable it, click start and type services.msc and look for superfetch.
I think it was Google who said that there was no discernible life span difference between hard drives that were under heavy usage 24/7 and drives that saw relatively little usage.
What I presume is the source but I can't be bothered to read at 9am.
I really love Vista, the only things I turn off are windows defender (because anyone who gets spy ware deserves it for being an idiot) and the god awful windows sidebar.
what Sandbox software works well with Vista x64 ?
UAC and/or Virtual PC 2007
The former is included in Vista and enabled by default. The latter is a freeware download from Microsoft.
Wouldn't bother trying any other "sandbox" software as it will all be crap.
NathanE, there's VM Ware too. Which is actually better than VPC in terms of features and stability.
Oops forgot VMware - yes that certainly isn't crap :) Although I personally prefer the "lightweightness" of Virtual PC but I'm just wierd like that :D
