Permabanned
- 19 Jun 2007
- InURmama
Its an ASUS, stick some Corsair Dominator in it, pump it to 1200mhz
hopefully i won't have any problems, going to put the PC together soon
hmm worried now...Would my Corsair HX 620W ATX2.2 Modular SLI Compliant PSU be fine then ?
Got one of these nowhopefully i won't have any problems, going to put the PC together soon
Hmm these are the parts i've just got...
Samsung SH-S203NBEBN 20x DVD±RW SATA Dual Layer Lightscribe ReWriter (Black) - OEM
Gigabyte 3D Aurora 570 Black No PSU
Zalman CNPS9700-LED CPU Cooler (Socket 754/939/940/AM2/LGA775)
Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR 95W Edition" 2.40GHz
BFG GeForce 8800 GTX OC2 768MB GDDR3 HDTV/Dual DVI (PCI-Express)
Western Digital Caviar SE16 500GB SATA-II 16MB Cache
Microsoft Windows Vista Home Premium 64-Bit Edition DVD - OEM -
Samsung SM-226BW 22" Widescreen LCD Monitor - Glossy Black
Western Digital Raptor 150GB 10000RPM SATA 16MB Cache
Creative Sound Blaster X-Fi Xtreme Gamer 7.1 Sound Card - Retail
Asus P5N-T Deluxe nForce 780i (Socket 775) PCI-Express DDR2 Motherboard
OCZ 4GB (2x2GB) PC2-6400C5 800MHz SLI-Ready Edition Low Latency Dual Channel DDR2
I got told by many on this board that my 620W PSU will be more than enough for Sli with 2 8800 GTX' is that correct then? Will this setup be fine with the board, and will my RAM be okay?
I am using the Corsair stuff of the same spec and had loads of problems... Hopefully the OCZ SLI Stuff should work fine...
Gonna replace the CPU tonight then i would be confident in saying the motherboard is faulty...
Just freezes. It is possibly some sort of heat issue as you get further through the install if the machine is cold...
