- 7 Feb 2004
I am using rivatuner to overclock my card and am unsure how accurate the temps are on the monitor hardware.
Pushed to 645/1515/1010 and got 11509
My temps are showing 51 - 61 idle and 71 - 86 pushed
My quiry is that on Atitool the temps seemed higher than those on nivatuner.
Is nivatuner ok for monitoring temps?
. I think (not sure) the normal OC is about 630-650Mhz core > 1600-1650Mhz shader > 1050Mhz memory. So on that regard you're doing a bit better than average but with limited knowledge I'm not the best judge on that question. Loadsamoney as well as a few others should be able to help out more in that regard as I've never owned or tried the 320Mb model.
