- 5 Oct 2005
- UK - Paignton
Hi all.
Last week I had a Nokia 6120 classic for a few days on the 3 network(payg) before taking it back due to their branding which had removed the gsm only option under network mode. I also just found out that even if the setting was there it will change straight back to 3G/dual mode within minutes due to 3 only wanting you to use their own network and not piggy back off the others.
My area is right in between having/not having 3G so a lot of the time the mobile was trying to switch between 3g/non 3g which meant it was hard to hold on to a signal a lot of the time. Later on up the line perhaps I,ll go back on 3 as I'm meant to be moving house soon so the coverage might be better. In the meantime its a no no.
I loved the 6120c itself mind you for the short time I had it and was all set to order a non branded/unlocked one from a certain jersey site when I spotted the E51 for slightly more.
From what I can see from reading reviews the E51 is slightly improved with a better case, nicer keypad/shortcuts, more inbuilt ram, wi-fi and better functions for business users.
Does anyone have any experience with using this mobile at all?
Minus the flash/not having a camera on the front is the quality of the camera the same?
How good/reliable is the wi-fi?
How would you rate the battery?
Any features missing from it that are on the 6120c that you are aware of and any negative comments you can point out?
Thanks.
Thanks.
