Hi there
We have a truly amazing deals for you for until 4pm Wednesday 16th January on our most popular OCZ memory lines:-
OCZ 4GB (2x2GB) PC2-5400C5 Dual Channel Vista Upgrade Gold Series DDR2 (OCZ2VU6674GK)
The new PC2-5400 Vista Upgrade edition is optimized for perfect compatibility for those transitioning from Microsoft Windows® XP to Vista™. The OCZ Vista Upgrade series has gone through stringent testing with the full spectrum of Vista versions to deliver a perfect balance of memory performance and stability across the full range of applications. As a Vista up-grader, the PC2-5400 4GB dual channel kit will provide excellent memory bandwidth and deliver the most efficient operation possible, ensuring the best possible gaming and productivity on Vista systems. Each memory module features a proprietary OCZ XTC (Xtreme Thermal Convection) heatspreader for the most effective heat dissipation. Furthermore, each OCZ Vista Upgrade module is 100% hand-tested for quality assurance and compatibility and is backed by an industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
* XTC (Xtreme Thermal Convection) heatspreaders optimize the thermal management of memory modules by promoting greater airflow by means of micro-convection throughout what is usually the dead air space inside conventional heatspreader designs. In this manner, build-up of heat is avoided and thermal dissipation of the memory components is offloaded more efficiently through the honeycomb design. At the same time, mechanical stability is maintained.
- 667MHz DDR2
- CL 5-5-5-15 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- Copper Mirrored XTC Heatspreader*
- Lifetime Warranty
- 1.8 Volts
- 240 Pin DIMM
- 1.85V EVP - OCZ's unique Extended Voltage Protection feature allows PC2-5400 modules to handle voltages up to 1.85V ±5% and still be covered by our Lifetime Warranty.
Previously sold for £59.99+VAT (£70.49 Inc. VAT)
Price: £49.99+VAT (£58.74 Inc. VAT) (£11.75 Saving!!)
BUY NOW!!
OCZ 4GB (2x2GB) PC2-6400C5 Dual Channel Vista Gold Series DDR2 (OCZ2G8004GK)
As part of OCZ’s Gold series, the PC2-6400 2GB modules deliver the performance and speed gamers require for today’s graphic-intensive DirectX 10 PC games. At 800MHz, the 2GB Gold Edition runs at 5-5-5 latency timings and offers unprecedented stability on the latest AMD and Intel platforms. As a Vista up-grader, the PC2-6400 4GB dual channel kit will provide excellent memory bandwidth and deliver the best possible gaming and productivity on Vista systems.
All Gold Edition modules are 100% hand-tested for quality assurance and compatibility and feature high quality, gold-mirrored XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ Gold series module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.1V ± 5% without invalidating their OCZ Lifetime Warranty.
- 800MHz DDR2
- CL 5-5-5-18
- Unbuffered
- Gold XTC* Heatspreader
- OCZ Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
Previously sold for £69.99+VAT (£82.24 Inc. VAT)
Price: £54.99+VAT (£64.61 Inc. VAT) (£17.63 Saving!!)
BUY NOW!!
OCZ 4GB (2x2GB) PC2-6400C5 800MHz SLI-Ready Edition Low Latency Dual Channel DDR2 (OCZ2N800SR4GK)
New OCZ PC2-6400 4GB kits are the world’s first 4GB NVIDIA nForce SLI Certified kits and are designed for ultimate gaming performance on NVIDIA nForce motherboards. The new OCZ PC2-6400 4GB SLI-Ready Series is equipped with NVIDIA Enhanced Performance Profiles (EPP) to optimize the modules’ gaming performance on nForce® SLI-based motherboards. Designed to deliver exceptional memory performance with the latest DX10 games OCZ exclusively has engineered select high-performance 4GB memory SLI kits with advanced SPD (Serial Presence Detect) settings to allow compatible motherboards to recognize and utilize the added information, ultimately increasing the performance potential of the entire platform. OCZ PC2-6400 4GB SLI-Ready memory modules are programmed to boot at 800MHz DDR2 with tight timings of 5-4-4. Only motherboards equipped with the custom-designed BIOS, such as those designed for NVIDIA nForce SLI MCPs, can detect the optimized SPD profiles and ensure the memory functions under the best possible conditions. The exclusive OCZ SPD specifications take out the guesswork and provide enthusiasts and gamers with significant overclocked performance with no manual adjustment or compatibility issues. Each OCZ SLI-Ready module comes equipped with an exclusive NVIDIA XTC heatspreaders for the most efficient heat dissipation and a look that stands out like its performance. Additionally, all SLI-Ready memory is backed with toll-free technical support, the exclusive EVP (Extended Voltage Protection) coverage, and an industry leading Lifetime Warranty. With the fusion of the sophisticated EPP memory specification, high-speed OCZ DDR2 architecture, the PC2-6400 4GB SLI kits are the ultimate breakthrough for advanced SLI platform gaming performance.
- 800MHz DDR2
- CL 5-4-4-15-2T (CAS-TRCD-TRP-TRAS)
- SLI XTC* Heatspreader
- 2.1 Volts
- 240 Pin DIMM
- OCZ Enhanced Latency Technology
- 2.2V EVP**
Price: £59.99+VAT (£70.49 Inc. VAT) (£11.75 Saving!!)
BUY NOW!!
OCZ 4GB (2x2GB) PC2-6400C4 800MHz Reaper HPC Enhanced Bandwidth Edition Dual Channel DDR2 (OCZ2RPR800C44GK)
The Reaper HPC is an innovative patent-pending cooling solution developed by OCZ to effectively minimize heat produced by high-speed memory. As heat rises into the thermo-conductive copper heat pipe conduit, it is dissipated through the strategically-placed compact aluminum fin array. By guiding performance-robbing heat away from key memory components, the unique Reaper HPC design helps facilitate improved overclocking performance, while improving longevity and stability of the modules. This high-density 4GB kit is ideal for running any enthusiast or profession system at maximum performance. At 800MHz, the 4GB Edition runs at 4-4-4 latency timings and offers unprecedented stability on the latest AMD and Intel platforms. As a Vista up-grader, the PC2-6400 4GB dual channel kit will provide maximum memory bandwidth and deliver the best possible gaming and productivity on Vista systems. As part of OCZ’s line-up of premium memory, PC2-6400 modules are backed by a Lifetime Warranty and industry-leading technical support.
* The Reaper HPC series uses heat pipe technology to rapidly remove heat from the main body of the memory modules and conduct the thermal load to the extended radiator fin array. The addition of the extended fin array nearly doubles the total surface area available for heat dissipation while the heat pipes warrant near isothermicity throughout the entire design. The result is a doubling in effective heat dissipation at equal delta t or, in real systems, a significantly lower operating temperature of the memory modules.
**OCZ EVP (Extended Voltage Protection) is a feature that allows performance enthusiasts to use a VDIMM of 2.2V without invalidating their OCZ Lifetime Warranty.
- 800MHz DDR2
- CL 4-4-4-15 (CAS-TRCD-TRP-TRAS)
- Patent-pending Reaper HPC Heatsink
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
Previously sold for £79.99+VAT (£93.99 Inc. VAT)
Price: £64.99+VAT (£76.36 Inc. VAT) (£17.63 Saving!!)
BUY NOW!!
OCZ 4GB (2x2GB) PC2-6400C4 800MHz ReaperX HPC Enhanced Bandwidth Edition Dual Channel DDR2 (OCZ2RPX800EB4GK)
These high-performance modules will support the latest games and top of the line multimedia programs with a 4GB capacity, combined with the high frequencies and aggressive bandwidth for maximum system stability. Rated at DDR2-800 with 4-4-3 timings, the PC2-6400 ReaperX provides exceptional latencies for the extreme enthusiast and gamer. The sheer speeds combined with the 4GB capacity of this kit will provide you with unsurpassed reliability, system responsiveness, and stable performance. Featuring an EPP (Enhanced Performance Profiles) programmed SPD, PC2-6400 Reaper X modules will immediately boot at the rated specs on the latest generation of NVIDIA® SLI™ chipsets. Although the OCZ Reaper X series caters to enthusiasts, EPP eliminates the need for manual configuration and makes the benefits of overclocking available to the complete range of consumers looking to get the most out of their systems. As one of OCZ’s legendary Enhanced Bandwidth (EB) editions, the ReaperX 4GB kit increases effective memory bandwidth through the optimization of memory latencies between the system memory, the chipset, and memory controller, resulting in the ideal balance of speed and enhanced timings.
- 800MHz DDR2
- CL 4-4-3-15 (CAS-TRCD-TRP-TRAS)
- 2.1 Volts
- 240 Pin DIMM
- Enhanced Performance Profiles (EPP)
- 2.2V EVP**
Previously sold for £89.99+VAT (£105.74 Inc. VAT)
Price: £74.99+VAT (£88.11 Inc. VAT) (£17.63 Saving!!)
BUY NOW!!
OCZ 8GB (4x2GB) PC2-6400C5 800MHz Quad Channel Platinum Low Latency XTC Series DDR2 (OCZ2P8008GQ)
The PC2-6400 8GB Quad Kit is ideal for enthusiasts, professionals, and DIY system-builders using Windows® Vista™ as their choice operating system that require the performance of high-speed memory. The ultimate upgrade for hardcore gamers, the latest PC titles require large capacity memory to deliver the most powerful, stable system performance and maximize gameplay. The PC2-6400 8GB Platinum Edition is the ultimate memory solution for the latest visually-intensive PC titles, and provides unsurpassed reliability and performance to unleash every graphic possibility. The 800MHz Platinum Edition runs at exceptional 5-4-4 timings, offering tighter latencies than typical 2GB modules, and provides unprecedented bandwidth on the latest platforms. As part of OCZ’s Platinum series, the PC2-6400 8GB Quad Kits are engineered to satisfy the demands of overclockers and enthusiasts with an optimal balance of performance, overclocking strength, and capacity. The 8GB PC2-6400 Quad Kits are 100% hand-tested for quality assurance and compatibility and feature high quality, platinum-mirrored XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind. With its ultra-fast performance, high quality and reliability, the OCZ PC2-6400 Platinum 8GB Quad Kit is a perfect memory upgrade for today’s memory-hungry Intel platforms.
- 800MHz DDR2
- CL 5-4-4-18 (CAS-TRCD-TRP-TRAS)
- Platinum Mirrored XTC* Heatspreader
- 2.1-2.2 Volts
- 240 Pin DIMM
- 2.2V EVP**
Previously sold for £129.99+VAT (£152.74 Inc. VAT)
Price: £109.99+VAT (£129.24 Inc. VAT) (£23.50 Saving!!)
BUY NOW!!
OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2 (OCZ2P800R22GK)
OCZ PC2-6400 Platinum Revision 2 is the latest version of the Platinum DDR2-800 Series. The PC2-6400 Platinum Rev. 2 has been re-engineered to turn out heart-pounding 4-4-4 timings with flawless performance and stability and offer lower latencies than standard 800MHz DDR2 memory.
OCZ exclusively developed these modules for the extreme gamer and overclocker to give high-end DDR2 based systems that extra performance edge that is demanded by today’s hard core gamers and enthusiasts.
The new OCZ PC2-6400 Platinum Rev. 2 utilizes the latest OCZ heatspreader design. XTC (Xtreme Thermal Convection) Heatspreaders allow increased ventilation and heat dissipation due to an innovative honeycomb design providing more direct access to the actual memory ICs.
As part of the award winning OCZ Platinum DDR2 series, the PC2-6400 Platinum Rev. 2 is built with leading edge technology designed and qualified with special selection of premium components to maximize performance in even the most demanding computing environments. OCZ PC2-6400 products are 100% hand-tested to ensure compliance with stringent quality standards. In addition, each member of the OCZ Platinum family is backed by an industry-leading lifetime warranty, toll-free technical support and the exclusive EVP (Extended Voltage Protection) coverage.
With its ultra-fast performance, high quality and reliability, the OCZ PC2-6400 Platinum Revision 2 edition is a perfect memory upgrade for the latest CPU arrivials.
- 800MHz DDR2
- 1.9-2.0 Volts
- 240 Pin DIMM
- 2.2V EVP**
Previously sold for £31.99+VAT (£37.59 Inc. VAT)
Price: £28.99+VAT (£34.06 Inc. VAT) (£3.53 Saving!!)
BUY NOW!!
OCZ 2GB (2x1GB) PC2-8500C5 1066MHz SLI-Ready Edition Dual Channel DDR2 (OCZ2N1066SR2GK)
New OCZ PC2-8500 Memory Modules are NVIDIA nForce SLI Certified resulting in better performance with select NVIDIA nForce motherboards. The new OCZ PC2-8500 SLI-Ready Series is equipped with NVIDIA Enhanced Performance Profiles (EPP) to optimize the modules’ performance on nForce® 590 SLI-based motherboards. OCZ exclusively engineered select high-performance modules with advanced SPD (Serial Presence Detect) settings to allow compatible motherboards to recognize and utilize the added information, ultimately increasing the performance potential of the entire platform. OCZ SLI-Ready memory modules are programmed to boot at 1066MHz DDR2 with supremely fast timings of 5-5-5. Only motherboards equipped with the custom-designed BIOS, such as those designed for NVIDIA nForce 590 SLI MCPs, can detect the optimized SPD profiles and ensure the memory functions under the best possible conditions. The exclusive OCZ SPD specifications take out the guesswork and provide enthusiasts and gamers with significant overclocked performance with no manual adjustment or compatibility issues. Each OCZ SLI-Ready module comes equipped with an exclusive NVIDIA XTC heatspreaders for the most efficient heat dissipation and a look that stands out like its performance. Additionally, all SLI-Ready memory is backed with toll-free technical support, the exclusive EVP (Extended Voltage Protection) coverage, and an industry leading Lifetime Warranty. With the fusion of the sophisticated EPP memory specification and cutting-edge, high-speed OCZ DDR2 architecture, the PC2-8500 edition is the ultimate breakthrough for advanced SLI platform performance.
- 1066MHz DDR2
- EPP 5-5-5-15 (CAS-TRCD-TRP-TRAS)
- Unbuffered
- SLI-Ready XTC Heatspreader*
- Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- NVIDIA® SLI™ certified
- 2.4V EVP**
BUY NOW!!
These are absolutely amazing deals, especially considering memory prices have hit a bottom and are now and have already increased due to the ever decreasing dollar rate due to a strengthening US economy which makes these deals particular special and an ideal time to buy.
- 667MHz DDR2
- Unbuffered
- Lifetime Warranty
- 1.8 Volts
- 240 Pin DIMM
BUY NOW!!
- 800MHz DDR2
- CL 5-5-5-18
- Unbuffered
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
BUY NOW!!
- 800MHz DDR2
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
BUY NOW!!
- 800MHz DDR2
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
BUY NOW!!
- 800MHz DDR2
- 2.1 Volts
- 240 Pin DIMM
- 2.2V EVP**
BUY NOW!!
- 800MHz DDR2
- 2.1-2.2 Volts
- 240 Pin DIMM
- 2.2V EVP**
BUY NOW!!
- 800MHz DDR2
- 1.9-2.0 Volts
- 240 Pin DIMM
- 2.2V EVP**
BUY NOW!!
- 1066MHz DDR2
- Unbuffered
- Lifetime Warranty
- 2.1 Volts
- 240 Pin DIMM
- 2.4V EVP**
BUY NOW!!
