Enemy Territory: Quake Wars v1.4 Patch
Caporegime
8 Sep 2006
On Ocuk
Front End
Hot Servers listing added to the server browser (includes listing of number of players considering joining the server)
Server browser now updates player count the instant somebody chooses to connect to it
Added panel to the server browser screen that displays the users stats and awards progress
Ticker on server browser screen now links to external web sites
New options available on Play Computer screen
Additional option on the Game Settings screen (Advanced HUD, Respawn Text, Draw Fireteam List etc)
Play Computer
New Tutorial mode with pre-set bot skill levels
Key tooltips now briefly pause the game in tutorial mode to help lead the player
Tooltips played in tutorial mode now highlight corresponding HUD elements where appropriate
Additional new tooltips
Updated bot AI for Tutorial mode: bots play less aggressive, assist more and pace the completion of objectives
General
Head hitbox for player models adjusted, damage now scales better based on accuracy
New VO added for tooltips
Subtle Motivators added - When players achieve various records in-game they are told so via a pop-up message
Vehicles at the main base of either side are now immune to damage after spawning, immunity is lost when used by a player
Spawning vehicles are now static until used by a player to avoid exploiting
Mines are now highlighted by green or red dots on the HUD
Fireteam leaders are now displayed with White player arrows, fireteams with Yellow arrows and friends with Cyan arrows
Vampire Strike beacon smoke effect has been updated
Revive missions for Medics/Technicians are now Tasks
Matches can now be paused mid-game via 'pausegame' or 'admin pause/unpause'
Player models on the limbo menu now rotate 360 degrees when a class is first selected
Buttons added to mute limbo menu voice tutorial
End game stats screen has been updated with new stats info (Next Award, Rewards gained this campaign, Personal Bests, Mouse over info on map awards like Best Engineer)
Advanced HUD option (moves text, reduces space used by obituaries and moves subtle motivator pop-ups)
Deployables now display the owner's name on Crosshair info
New HUD icons for parachuting/air-shield and Third Eye Camera
Reduced decoy fire rate on Tormentor and Anansi
Reload time increased on Anansi Rockets and Tormentor Plasma Cannon
Reduced damage done to deployables by Anansi Rockets and Tormentor Plasma Cannon
Re-balanced Anansi and Tormentor XP
Basic hacking has had its time reduced and can now also cause damage when hacking an already disabled deployable
Slightly updated effects on Violator
Sniper Rifle and Railgun trails are now more obvious/longer duration
Stroybomb reload time increased slightly
Adjusted the point at which the attacking team gets a reduced spawn time
Progress decay on some objectives has been adjusted
Player's now receive a warning when a turret is targeting them or when they have triggered a mine
Added more support for loading mods
A message is printed on the HUD when someone finishes hacking a shield generator
The game running in fullscreen no longer forcefully captures the mouse, resulting in better multitask behaviour
'vstr' now evaluates immediately, rather than adding its output to the end of the command buffer
Workaround for certain ISPs filtering out legitimate authentication and match making packets
Multiplayer stereo sound separation algorithm alternative from Quake 4 added, s_earSeperationAlgo 1 to enable (Default and legacy is 0) two additional cvars for control: s_esa1_minVolume (sound never drops below this fraction for either ear), s_esa1_maxWindow (window size in which volume is maxed, fraction of full range)
Text declarations now take priority over binary ones to make mod development easier
WriteJumpStartDemo now overwrites existing files
Added local stats tracking for offline play
Increased XP reward for players picking up your Health Packs, Ammo Packs and Stroyent Cells
Added green repair indicators if someone repairs your vehicle.
The icarus is now more forgiving to lock on to
The MCP auto-deploys when it has been in the deploy zone for half a second, deploy text on HUD removed.
MCP does not take damage unless it can move
MCP driver can now remain inside the MCP when it is disabled
MCP driver MG cannot be used when the MCP is disabled
Shotgun pellet count reduced and fire rate increased
Assault Rifle and Lacerator base weapon accuracy increased
Sprinting will now pull you out of sighted/scoped mode
APT turrets now have a 1.5 second delay before it starts turning towards the player.
ETQW:TV
Added support for spawning repeater server on dedicated server, net_spawnRepeater 1 to enable
Added support for connecting repeater relay servers to other repeater servers, net_spawnRepeater 1 to enable
The port the repeater will use can be controlled by net_repeaterPort, the default is 27833 is no port is specified
Use ri_maxViewers to control viewer slot limit for repeater servers
Access to the repeater can be limited by the use of ri_useViewerPass, g_viewerPassword, g_repeaterPassword, ri_privateViewers and g_privateViewerPassword
Repeater server name can be controlled by ri_name
Viewers may chat to other viewers on the same repeater server, this can be disabled with g_noTVChat
Viewers may cycle through player views by pressing the attack key, and free fly using the alt attack key
Broadcasting can be delayed by changing net_clientRepeaterDelay, this is only supported on repeater relays
Repeaters can be set up to auto-download required content by setting net_clientRepeaterAutoDownload to 1
For additional information on the ETQW TV feature, please see the ETQW TV Readme file.
Bug Fixes
Fixed saving some passwords causing the local account to be corrupted
Fixed typing quickly scrambling user input
Fixed typing while holding down Shift sometimes causing text overwrites
Fixed low apparent texture quality if texture quality settings were below the baseline
Fixed an intermittent crash on startup during the "Loading UI..." stage
Fixed crash when loading a map on ATI brand cards
Fixed serverInfo command incorrectly reporting server status
Fixed filters being applied to History and Favorites list
Fixed auto-updater being used when running from the Steam version of the game
Fixed ServerLauncher not reloading the last opened profile
Fixed ServerLauncher not properly setting the mod
Fixed being able to corrupt user chat history
Fixed a crash when deleting the last item in the replay list
Fixed sometimes being able to send empty messages when chatting
Fixed jittery bots & vehicles when playing against the computer with unlockFPS on
Fixed clipping through ceiling when getting out of the Husky in specific locations
Fixed Player.cpp bad floating point dump-to-console error
Fixed GDF deployable "jerk" on landing
Fixed servers having incorrect antilag tuning - antilag tuning CVars are now read-only
Fixed infiltrator being able to teleport without having full charge
Fixed bugs with accurized lacerator/scoped assault rifle scoping & unscoping
Prevented vehicle view FOV issues - FOV limited to 90 when in vehicles
Fixed loading screen sometimes showing previous server's information
Fixed relative directory name detection incorrectly marking certain paths as relative, resulting in problems when attempting to create directories or files
Fixed offline friends in the friends list incorrectly appearing as if they were on a server
Fixed 5.1 and 7.1 audio not working in certain surround configurations
Fixed mouse buttons not being swapped correctly when the raw input api was used
Fixed autocompletion not working in certain situations for files that exist in PK4s
Fixed bindings.cfg able to be being executed multiple times in a frame due to input language switches, potentially resulting in keys not being bound
Fixed projection matrix jittering being applied in cases where it shouldn't (for example, waypoint icon coordinate calculation)
Fixed not always clearing the fireteam name edit box before opening it.
Fixed 'create' on fireteam menu when trying to create more than 8 fireteams.
Fixed playing OOB tooltip even though player was dead.
Fixed inverted "blocked you"/"unlbocked you" tooltips in the friends list.
Fixed campaign tab being fullscreen when restarting map and going straight to the vote tab.
Fixed seeing the action icon on enemy mines even though disarming was impossible from that distance.
http://www.gamershell.com/news/44677.html
Theyre good fellas at id software. Some nice patches come out for QW.
Compare this to patch and update support for Gears of War pc
It is a very good patch.
The patch adds a lot of features that make the game feel more like BF2 and I have yet to find any adjustments that I don't agree with.
On the whole a great patch. I just wish they would introduce more maps :D
QW:ET is such an overlooked game. If you like BF2, Wolf:ET and/or Quake then you cannot fail to like it.
Picked the collectors edition of this up the other day for £10 at a high street store, its very bf2142 like to me, still not 100% sure on everything yet, but i think it was a good buy.
It's not really overlooked. A lot of us played it when it first game out and found it to be pants compared to bf2/2142 and TF2.
Does sound like a good patch though.
One of the big things about ETQW was that the objectives aren't very obvious to newbie players. This means that the pubs often turned into spam-fests because people didn't know what to do so just treated it like an FPS. I'd imagine that's not an issue anymore with the more experienced playerbase though.
Still remember just getting into the swing of things in closed beta when the open beta started (and for some reason not all of us in closed got open beta keys - le sigh) and all the closed beta servers were dead from then onwards. Le fun.
i bought it on steam for $20 a few months ago, but have yet to get to grips with the game mechanics. It runs extremely well and very smooth but i've just not got round to playing it proper due to Team Fortress 2.
OK... this is old news.. why did someone bring it up?
This is my main game for the last three months...
Quake ET is an awesome game that forces people to play a variety of classes and is based around working as a team to complete objectives.
Okay I admit it is no tactical shooter, but I would describe Quake ET as an arcade FPS A LOT like Wolfenstein ET; It is GOOD FUN and easy to jump into for 10 quick minutes of play or for 3 hour sessions.
It defiantly isn't what people whom are looking for glory as a super uber l33t sniper wolf god, but I hate those types of games anyway because it breeds useless idiots with no team skill what so ever who are totally obsessed with ranking top of the kills rank.
High kill ratios are great, but alone they do not win objectives.
Winning rounds is my game and no matter how good a player, you wont beat a good team.
Team play > Sniper skills
Hardly, just means the bugs have been ironed out. Shame not all developers look after their games after release.
yeah it is nice of them to look after their customers but the game itself was a disappointment for me....i loved rtcw and quake is quake...a legend of a game if there could ever be one.
etqw just seemed like a battlefield2 clone but not as good.
my comments are based upon the beta as i never bought the full game
