Man of Honour
- 12 Jul 2005
- Aberlour, NE Scotland
Why use Fluid XP when distilled/de-ionised water from Halfords at around £5 for 5 litres does the same job? You can always add some UV dye for colour and some Zerex or similar as a corrosion/algae inhibitor. Nearly £52 is madness for some fluid. If you do it right and take your time and leak test it outside your rig you should'nt get any leaks.
