Out of those 2 you'd be better off with the front suspension bike. I personally wouldn't have either but if your getting it free then you may as well. The full suspension bike will weigh a ton and the rubbish suspension will just hinder your ability to ride uphill.
it would fall apart at the first sniff of a twig. But that xc is better than the two the op posted.
