WD AAKS + AAM - watch out
20 Aug 2006
had 2 new shiney 500gb AAKS's arrive yesterday
installed them as RAID0
rain some tests and was horrified to find random access time of 19.5ms !!
did some searching on the net and found that could be that AAM was on - sure enough it was - and on full ! - ie full quiet.
Downloaded the hitatchi feature tool bootable ISO, then in my case as drives were set to RAID and it couldn't see them in that mode I had to switch in bios to SATA compatible mode (which in my case didn't destroy my RAID but beware), then for each drive - instead of turning AAM off I just slid it all the way to the right - as custom AAM - ie max performance
before - random access = 19.5ms
after - random access = 13.4ms !
hope this is of help,
Mark.
Sandra SI will warn you in the ATAPI Section (used to be on older builds)
And Hitachi tool will show you its ON and what LEVEL its at.
Raptors are also set to ON, I kill it totally on any drive I have thats supports it.
Cheers for that mate. Just run Sandra SI and found it was set to ON for my Raptor (but not for the Barracuda). Will get that turned OFF right now. :)
Nice one!
Ive just done this on one of my WD320AAKS and its dropped my access time from 18 to 12.9. :D A lot louder though. Thing is, only one of my HD's show up in Hitachi tool :confused:
Uggh, having problems burning this with imgburn - where can I find a file to make it bootable?
Download it from MajorGeek, just go to the CD-ROM .iso one and it the bottom it lists a link for the floopy version. Lol actually to save you hassle, here is the link,
http://www.hitachigst.com/hdd/support/downloads/Ftool-ver208.exe
Are your drives much noisier now btw?
Haven't noticed my drive being any louder, however it may be because even though the AAM was enabled, it was set to performance. So i've probably been running at full levels anyway. ;)
mmm interestingly my AAKS's aren't any much louder - possibly a tiny tiny bit - but not noticeable - still almost completely silent
but a lot quicker :)
glad this thread has helped some people out
question - why would WD release some identical drives out (1) with AAM on and (2) AAM off
I read this thread thinking woo! faster raptor. Until i used the drive tool, and it was already set to disabled. I even used HDTach before to get a comparison. 7.9ms Access time 77Mb/s sustained transfer. Was hoping for more performance. :(
