SLI seems to be cpu limited showing it ain't that great.
I don't see how it even could behave as a single card, when amd have been trying for years to do the same thing with cpus and failed.
The results I posted were a composite of results from real tests...
What I was trying to point out is the what if - I'm not saying increasing the CPU _would_ change the results... what I'm saying is the results don't have any hard conclusive evidence that changing another system component wouldn't have resulted in a different set of scores for the 8800 - the results do not tell you why the 8800 scored where it did and as its the highest scoring system you have to ask what if...
again if the results were reversed...
8800 GTX Single: 38fps
3870 single: 45fps
8800 GTX SLI: 72fps (+89.5%)
3870 CF: 76.5fps (+70%)
I wouldn't be saying hey SLI scales better than crossfire because I just can't draw a conclusion from those results what the top end of the higher scoring system really is.
Do you have a source for those results or did you just make them up?
That looks like the single GTX is under performing not that SLI is scaling better.
Have a look at this, it compares the GT in sli with the 3870 in xfire
http://en.expreview.com/?p=53&page=1
it still would be a SWEARY to put in antec 900 it would fit as i moded the case to fit 2900 but it would be really close
Rroff give up you have lost.
Crossfire gives a better performance increase over single card solution that SLI in general. Hence how it can be said that it scales better.
I see you have GX2, would this be pushing you towards defending your purchase or something? Nobody really cares to be honest, the GTX are beast cards, but when you stick 2 together the gains are just not good enough. Whereas 3870s should have been better, but its good that sticking 2 together does offer acceptable performance boosts
My scores were a composite from scores here...
http://it-review.net/index.php?option=com_content&task=view&id=1337&Itemid=91&limit=1&limitstart=1
Which is actually the 2900XT crossfire but the 3870 crossfire results show a similiar differential to the SLI setups they are compared against.
