Hope to get some opinions on this:
I want to upgrade to a 8800gtx but don't know whether I'll get a lot of benefit considering the rest of my system isn't the fastest/best and whether I should rather save the cash and go for a 8800GT. Only problem is I do have a 24" Dell monitor and could do with some 1900x1200 gaming, or something close to it
My system:
Antec P182
Corsair HX 620W PSU
AMD x2 3800+
ASRock Dual SATA MB
2gb Crucial Value Ram ( I was budget restricted when I upgraded ! )
Asus 1950Pro 256mb
I mostly play FPS and Pro Evo, don't need much for Pro Evo but best I've been able to play on FPS in widescreen is HL2/TF2 at 1440x960
I've read a lot of reviews on the 8800gtx, but couldn't actually find one that was running on a AMD x2 3800+ kinda setup like mine, so not sure if I'll come close to getting the fps that the dual core 2's were getting in the reviews
So, with this spec PC, is it worthwhile getting the 8800gtx ( probably just go for the OC 8800gtx ) or should I rather go for a 8800GT and try to upgrade mb/cpu/mem in a few months time?
My system:
Antec P182
Corsair HX 620W PSU
AMD x2 3800+
ASRock Dual SATA MB
Asus 1950Pro 256mb
but please remember to overclock that CPU to 2.6Ghz and above if you can. If you're running the stock heatsink then I'd invest in an Arctic Cooling Freezer Pro.
one hell of a deal that was
