- 2 Dec 2006
A bigger screen at the same resolution should hold the same amount as a smaller screen at the same resolution.
Noteable you ignored this because it makes sence.
I would still be sitting the same way away.
The pixils are smaller. This means the jaggidys get smaller too, because there is lots of small ones it has the effect of smoothing it out.
Zoom in on a picture and it goes all jaggidy. Zoom out and make the pixils smaller and they dissapear.
