Permabanned
- 18 Jul 2006
- Frodsham
To my knowledge though there is no proof that the games will work once you remove the padded/duplicated files, I would imagine if/when it is hacked they will have to be 1:1 copies to begin with and then "ripped" versions later on with redundant data removed, once people learn the system better.
I am fairly sure the ps3 has lasted the longest so far (released 13/14 months ago now?) than any other console/handheld this gen.
rp2000
It depends on what you consider hacking as not all 360s can be hacked, it depends on the drive. So, although so can there is still a large percentage that can't be
