Heres a stone cold bargain
There was one Leadtek 8800 GTX for £186 inc VAT available last night but I simply can't justify it. Was very tempted though.
I almost drove to OCUK and got that this morning. Was there still there about half 9. I could have been there for 9 but had to stop myself!
Thinking that an OEM card would come with no cables, I ordered a separate molex-to-pcie power converter. Having since read a review it seems that you need 2 6-pin power connectors to run it. Does anyone know if I'll get a couple of cables with an OEM card, or even if it'll run with just one 6-pin plugged in?
There were a pair 7800GT cards and a 7600GT card on last night, the 7600GT was £17 and the 7800GT were £23.
If any of them had been there when i went ocuk this morning id have had them as backup cards
BFG GTS 640mb OC2 for £130 - think I got the last one, being delivered tomorow...guess there a bit of a bargain! Dumb question, do I have to use a same spec card/model etc for SLI?
Cheers!
Cheers!
320mb can be used with 640mb but the card can only use 320mb in total. as for brand if you are pairing up an overclocked version with a stock version, the oc version will run at stock speeds.
