all looks fine, you could get away with the HX520 instead of the HX620 though
, I'm certainly enjoying my gaming at the moment
. Not sure about the P35 boards with no experience with them but I doubt it should have any major problems but maybe best waiting on someone's advice that knows something about the board or have you seen some reviews at least.Keep the HX620 unless you want to save a few quid. I had the option also and opted for the bigger PSU as you never know what you'll add to the system that might need it.
Rest of the system is looking great, I'm certainly enjoying my gaming at the moment
I've been hunting round the forum's and looking at other people's builds that have them in and it looks like a good enough board, the only thing im worried about is the BIOS version on it not being up to date with the new 8400's.
But all i need to do is put the latest bios on a mem stick and then flash the bios? considering this is my first build, how easy is that![]()
.good luck, give yourself time,room and decent lighting when you're set too start the build.
Should all be here tomorrow, got the big table in our uni kitchen to work on. Also the floors that lino stuff so no static![]()
. I look forward to hearing your results 2moro.
) so i'm going to sit down and read everything etc while i waitas already mentioned really, just take ya time, check the mobo stands are set into the case and match the mobo, double check all connections.
most of all have fun![]()
should be done in a few hours hopefully
