Playing Divx Files in WMP11 Question
29 Sep 2004
Wilt of the Shire
I've got some divx files that I can already play in WMP11. However, if I select several to play only 1 shows up in the playlist. How do I add several so they'll play 1 after the other or can't I do this in WMP11?
if you have a playlist at the side, you should be able to drag files on to it.
or in explorer, select multiple files, right click, add to windows media playlist.
Cheers, dragging them over worked ok. Just doesn't work when you right click and select open with. That option only plays the first file.
