- 18 Oct 2002
General consensus on XS is the E2xxx chips typically wall @ ~ 430 FSB.
.me tooThat makes more sense to me.
i'm almost certain it's the board. might have to break it via RMA
any ideas?General consensus on XS is the E2xxx chips typically wall @ ~ 430 FSB.
Got mine last week, jumped straight into 375x8 for 3ghz, nice and stable on stock volts and was running at 46c at full load on Orthos.
It will run at 400x8 but it gets a bit too hot for my liking (heats the case up too much) and it needs a fair amount of voltage to keep it stable.
How do you mean too hot? If it'll do 375x8 with stock volts at 46c then it sounds like a chip that would do 3.4ghz without too much trouble?
It doesn't take much to overheat the inside of a case that's got an overclocked C2D and 2 overclocked 3870's![]()
You need to get wet then dude!![]()
Maybe cos it's a different mobo?
) but I can't seem to get it Orthos stable for a proper stress and temp test
Got my E2140 fairly stable at 3.2ghz with 1.344v. It'll boot to windows, play games etc but it tends to crash when given 100% load for any amount of time. Temps are sticking around 58c when game loaded (supreme commander gives it a good thrashing) but I can't seem to get it Orthos stable for a proper stress and temp test
