When did I mention thumbnails? Seems like your reading and comprehension issues are rearing their head again![]()
Please stop insulting other members or your little fun time here will be over.
You aren't looking close enough. Again you are showing your lack of knowledge here on the subject of GDI. If you were a programmer you would know that GDI was almost universally hated for how hard it is to maintain a flicker free and artifact free program...
eh? you're a weird one
i don't understand what you're trying to imply.
my point - Vista is optimal with 4GB+, why are you even trying to debate this.
I said zoom. XP picture viewer employs a high quality zoom algorithm. Vista picture viewer simply zooms in with no algorithm. This manifests itself not only when you use the 'zoom' function, but also when you view an image which is larger than your screen can fit. The resizing is of low quality in Vista. This isn't my uneducated opinion, this is easily verifiable fact.
You didn't answer then either...
Why haven't I ever heard anyone complain of their programs flickering or artifacting?![]()
In short: Vista's Superfetch pre-loads Photoshop and all it's ancillary files into RAM. It could do this weeks, even months, before you actually use Photoshop (depending on system uptime of course). So when you DO come to use Photoshop all the I/O requests that are made to the hard drive are actually automatically redirected by the I/O Manager in the kernel to where it already exists in RAM. This is called "memory mapped files".
Dirtydog, leave them on there crusade.[/IMG]
light duties - sitting on the desktop with explorer open and a few tabs of IE sure 2gb is ok
for ppl who like to use their machines with top performance 4gb is the sweet spot ...end of
2gb is fine for vista for gaming. That is the point. I'm not bloody well saying 4gb isn't optimal.
If you think 2gb will just "allow you to carry out light duties" then you are seriously incorrect.
It's just like in XP - 1gb is fine, that will allow you to have a great experience and just carry out light duties.
But again 2gb is optimal...
Can you not read? I'd check my post again![]()
Yes I understand that much, but supposing you start a machine from a cold start. Clearly Vista cannot possibly get any program into RAM quicker than XP because it is dependent upon the performance of the storage device, usually a HDD.
Bleh.
I'm arguing his points for not liking vista. I like XP and have no issues with it.
So...take your pictures elsewhere.
Who called DD an idiot?
The slowest part would be the user intervention though. Vista will have preloaded it before a user initiates a program call.
Burnsy
Feels like it...when I explained my experiences with Vista I've been called a liar or not done the updates, or something wrong with my PC.
Vista is quicker off the block then XP & i can start doing stuff as soon as i see the desktop.
@ NathanE.
What format are the vista icons using as they don't degrade as you zoom them, infact they look better the bigger you get. ?
