Adding a new reg key?
30 Jul 2004
East Sussex, UK
Howzit guys,
I removed my Logitech reg key for starting up SetPoint by mistake. Now the program doesn't have the option to enable it when the PC starts. Is there anyway to re-add this reg information so that when the computer starts it starts my SetPoint software, too?
Thanks guys. :)
Rob. :cool:
I would have done that, however I don't have a copy of the software anymore. I also, cannot download it at the moment. :(
Thank you, Marc.
Rob.:cool:
you're posting here but you can't download it? :confused:
anyway, just browse through the program files directory and find the file and create your own startup shortcut.
Yes Marc. That's because I am using a cellphone to connect to the Internet and do not have enough airtime to download the Logitech software.
Thanks for the help, guys.
Rob. :cool:
Why are you changing your font if you're short on time?
Because Caged, my Internet cost is measured by the amount of data I use. Not the amount of time I am connect to the service. Hence why I am able to stay on for long periods of time. ;)
Rob. :cool:
To be helpful, where abouts did you remove the key from? If it was just for your user then it might be in the .DEFAULT user as well.
Can't you just throw a shortcut to setpoint.exe in your startup folder?
I used Ccleaner to remove the key. I am going to try that option now.
Thanks, Caged.
CrazyDAJT: I work in a computer shop with Internet access, however I am on leave for two weeks. Will download it again when I get back in. :D
Rob :cool:
